95 integra distributor
have a 95 integra, and the distributor got stolen, can I use one off a 97,
or are they different,
thanks alot for the input, integra its the special edition, the plugs from the distributor are square, not round, can I do any changes to make a different year distributor work
Resident Ninja-photo'er
yes, as long as your trim is the same as the car your getting it off of... LS/GS/RS are all the same, GSR is diff.. and Type R is diff
WHAT OK YEAH!
Originally Posted by VPUPPY
I believe its just more than swapping plugs. I believe there is a small difference in the actual wiring.
Certified Rice-Rocket
the wires are the same...i have an obd1 engine/dizzy but i had to use and obd2 harness..i just swapped the plugs and soldered the wires together and it works perfect
