Auto tranny clunks going into D or R
Old 11-18-2005, 09:38 PM
Emmett03
Emmett03's Avatar
Default Auto tranny clunks going into D or R
Replaced the front dog bone mount, it helped a little but it still does it. Next step is to replace the tranny mount since the two side mounts seem to be in good shape. Any BTDT on the tranny mount? There is no rear motor mount, correct? Could this problem be a torque converter issue? Thanks for the help guys. Emmett
Also, I snapped the stud on the valve cover gasket, ordered a new one from the dealer, guess 18 lbs. was just too much. Does anyone know the specs for the valve cover nuts?
This is on the '92
Old 11-19-2005, 06:05 AM
Kai
Rotorphile.
Kai's Avatar
Valve cover nuts are usually 8ft-lbs.
Old 11-19-2005, 08:49 AM
Emmett03
Emmett03's Avatar
Default Found the problem
its the large motor mount under the intake manifold. Any suggestions on replacement? source?
