Vtec Controller?????
Old 11-15-2005, 10:19 AM
SIR2Civic
SIR2Civic's Avatar
Default Vtec Controller?????
What r they like?
are they worth the money?
what is the one to go for?
Thanks
Old 11-15-2005, 11:05 AM
Civic2Scooby
Civic2Scooby's Avatar
Originally Posted by SIR2Civic
What r they like?
Thanks
no
Old 11-15-2005, 11:57 AM
SIR2Civic
SIR2Civic's Avatar
no what?
Old 11-15-2005, 12:42 PM
InfiniteVTec
The Dealer
InfiniteVTec's Avatar
I personally wouldn't adjust Adjust V-tec unless boosting.
Old 11-15-2005, 12:51 PM
B16a2VTIguy
Built B16a
B16a2VTIguy's Avatar
Alot of ppl say there not very good.....i say they are good for the money so long as you dont have some awsome fully built motor.
If you havent done too many mods and just want a cheaper way of setting it up, a vtec controller is a easy piece of equipment to use. If you get your ecu re-mapped to your current set up then you can really fine tune your motor with it. Ive just installed one in my motor, despite of what loads of ppl said and i'm well happy with mine. I had a few flatspots and it really helped to smooth them out plus i was able to drop the vtec point alittle to 5300rpm.
Basically, if your looking for serious power and going a long way with your honda, get a stand alone unit.
If your just doing I/H/E and IM etc maybe some basic cams, then they can really help to smooth flatspots and tune the AFR.
Old 11-15-2005, 03:50 PM
Civic2Scooby
A: its VTEC there is no dash
B: what is your basis for adding this to the thread
anyhow...I will elaborate on my previous "no"
VTEC controllers are pointless. by the time you build the motor enough to need to adjust the VTEC engagement point than you are past the point of needing one because your tuner will set the crossover via Dyno tuning with your stand alone.....the only time I could think of would be if you changed your cams and they had a different point at which they made power.....VTEC controllers offer no gains to stock motors, Honda put them where they are at for a reason.
Old 11-15-2005, 07:44 PM
1995Civic
I hate ricers
1995Civic's Avatar
Just listen to Lee...he knows what hes talking about.
Old 11-15-2005, 07:49 PM
CivicRacr
CivicRacr's Avatar
i have the apexi vtec controller, set to stock crossover point, no fuel settings. its really point-less since everything on my car is stock except for intake and exhuast. only time i see it would benefit is with different cams, but even then i would just save the money and get a stand-alone ecu
Old 11-15-2005, 08:01 PM
1995Civic
I hate ricers
1995Civic's Avatar
:repost:
This was all just covered.
