Thread Tools | Display Modes |
#1 | |||||||
lots and lots of fail
FAQ: Accord 4th Gen 90-93 DTCs
2003 San Marino Red Accord Coupe EX-V6 6MT IMM244k miles ![]() www.lemons300zx.blogspot.com |
| Sponsored Links | ||
#2 |
wow, thanks so much for that info!!!
#3 | |
Quote:
Oh, if anyone gets any of these codes please post them in here.
#4 |
i followed the procedures above for obtaining the DTCs and also clearing them. i was thinking it was going to be very confusing, like watching morse code, but it was really simple (as long as you can see and can count!) and i got it on the first try, and cleared it just as easily.
the problem i had was my speedo dropped to zero this morning, then my check engine light came on, then i noticed extremely low idle (which may not be related to the other 2 symptoms). the car shop nearby didnt have the diag tools to obtain the DTC for why the check engine light came one so they were no help in this case. (issue was originally discussed here: http://www.honda-acura.net/forums/sh...d.php?t=206312) anyhow, it turned out to be Engine Code 17 = VSS as 98CoupeV6 was sure of in the first place =) just glad to know what the problem is and this info was key in me finding out |
#5 | |
Quote:
Code 41:
#6 |
bboy Wesley West
thanks for remembering us 4th genners!
Vid of the Week:Nasty Ray kills the beat. Dickies.Reebok.AdidasApparel.Mcdavid.Tribal |
#7 |
This thread kicks ass! Should definately be archived
I have a 91 that get a check engine light from time to time. If I put the key in the # II position and wait for the check engine light to turn off it will normally stay off. If I put the key in and start it up right away it will turn on sometimes and other times it wont. Next time I get the light I'll be sure to check under the rug for blinking lights. Also I've tried to reset the green maint req light by using the trip meter and key trick but it stays green. Does green mean good to go? Just bought the accord a month or so ago so yes I'm a noob
#8 | |
Quote:
I believe it's in the FAQ.The maint req'd light reset instructions have to be around here or in the owner's manual, you should definetly be able to turn it off.
#9 |
Yeah no owners manual with the car so I was searching the forums for the reset procedures. I tried the trick for the new gen cars a couple different ways with no luck. Would still like to know why the check engine light comes on. Seems like now that I know how to figure out what it is it never wants to come on now
#10 |
Banned
Transmission codes page not found.
Hello,
After some time now back with a newer, more modern and secure PC. No more people logging on as me. I am looking for transmission DTC's. The links in here must be outdated because it says the info is no longer available. Working on 1992 Accord with multiple trans DTCs as follows: Code 1 Code 2 Code 3 Code 5 Code 7 Code 8 Code 14 Can anyone advise on what these DTCs are or at least maybe post a link to where I can find them? Thank you |
#11 |
1990 Accord EX
Thanks for a great forum and thread.
I jumpered the diag connector on my 90 Accord and the "S" light gave me the following codes. 7 short blinks 8 short blinks When the light begins flashing, I lose 1st and 4th gear. If I turn the care off and back on, the light will reset, but once it shifts into 2nd, the "S" light starts flashing and no more 1st and 4th. Can anyone shed some light on these codes and some possible causes?
#12 |
I cant see the pictures for the codes, I get a code 8 or 9, the first blink seemed dim or like half a blink, so wasnt sure to count it.
Thanks for your help. At first the car runs normally until I get to overdrive and then it downshifts into 4 as the S light starts blinking. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
