99 Civic Idling Problems... getting closer???
Hey guys I got a 99 Civic and for the past 3 winters once the car warms up the idling drops to whatever the tiny line is 1mm up on the tach. I guess that's maybe 500rpm... it's enough to dim all my dash lights and cause the car to shake... and sometimes stall.
Anyways I was told to replace the EACV (had it cleaned by Honda... worked great for about a month... then back to shitsville again)... So I did... I got one from a wreck... installed it... now the problem is...
Idles ok til it warms up... then it jumps to 1700 for 5 seconds or so... drops to 800 then instantly back up to 1700 for a few 5 more seconds... then down to 800 then instantly back up to 1700... and it just keeps doing that.
Did I miss something... or do I have another bad EACV???
Any thoughts guys?
Thanks!!!
Any thoughts guys?
Thanks!!!
maybe, how many mileage does the car have? also just check for simple stuff like lose tb cable, cuz i had almost same problem like yours, but mine ran really high RPM when starting... found out my cable was really loose.
