1st to 2nd grinding at around 6000rpm pls help
Old 11-30-2004, 02:46 AM
slapmaho
slapmaho's Avatar
Default 1st to 2nd grinding at around 6000rpm pls help
94' LS 79,000miles
the problem im having is with grinding gears
from 1st to 2nd when i shift too quickly at anything
around 6,000rpm.
it grinds if i dont give it a second between gears, even
when I push the clutch all the way in.
I know its not my clutch, my clutch grips strong still
so I am considering short shifter or shifter bushings,
but i am unfamiliar with both of them, or maybe
i need my transmission flushed?
I want to be able to shift gears faster and smoother
without worrying about grinding, I have always driven 5spd
so im not a whack ass driver slamming gears.
Old 11-30-2004, 03:16 AM
PlastikOwl
PlastikOwl's Avatar
It has nothing to do with your clutch or transmission fluid. You can try some gm syncromesh fluid, but I doubt it will help much.
You have a bad synchronizer in your transmission. It's pretty common with honda transmissions.
Old 11-30-2004, 01:47 PM
GSRRacer95
Fight On!
GSRRacer95's Avatar
I just had my synchro's fixed. I had the same problem.
Old 11-30-2004, 01:49 PM
teg92
WHAT OK YEAH!
teg92's Avatar
I heard that short shifters will make your car grind gears
Old 11-30-2004, 01:55 PM
SP00NFed
FuK JDM
SP00NFed's Avatar
ShortShifters aren't good even if you go with something like the skunk2. I don't think bushings or a new shifter will fix your problem.
Old 11-30-2004, 03:57 PM
JoePoonani
Lexus Tech y0!!
JoePoonani's Avatar
yea its definaly your synchros, i have the same problem going into third at high RPMs. but im getting a rebuilt tranny with shorter gears so i dont have to worry anymore :exnbp:
Old 11-30-2004, 05:34 PM
dubcac
I
dubcac's Avatar
Wrong, another misconception. It's the driver's error, not the shifter.
Old 11-30-2004, 11:04 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
:werd: I have the skunk2 and have not once missed a gear. If you aren't reckless with the stick, it wont grind.
But yeah, it sounds like a synchro. I doubt it is worth it to get it replaced, so you might look for a used tranny somewhere.
Old 12-01-2004, 03:03 AM
slapmaho
slapmaho's Avatar
Heres the thing, I dont always have this problem, only occasionally.
also my transmission has been driven nicely and is very young,
it almost feels like my clutch is not disengaging fast enough, is that possible?
Old 12-01-2004, 07:30 AM
JoePoonani
Lexus Tech y0!!
JoePoonani's Avatar
does it only happen at high rpms? if so then it is just the first phase of your synchro going bad. if you dont want to grind when you're driving "spiritedly" from second to third you should try double clutching. if you dont know what that is, it is basically clutching out of second and putting it in neutral, releasing the clutch, depressing the clutch again, up shift, and release the clutch. i hope i described it well enough for you to understand.
