Rover Engine Conversion....
Old 11-02-2004, 01:35 AM
Wilson
Wilson's Avatar
Default Rover/honda D16 to b series Engine Conversion....
Hi all, i really don't have any basic knowledge of anything much about this,
hope i can get sum pro's opinion on this!!
i currently have a rover216coupe. with a Honda d16a6 engine in it. its Too slow for me! i have just bend sum valves, cylinders are all runing on very low compression, sumtimes wont start! so i have an idea! but i dont know whether it will work? help!
i want a b18c1 engine conversion. or integra type R engine. is it possible??? preferably the typeR....
the mounts.... the chassis, wot abot the engine main cable?
whats the first thing i need? wot upgrades do i need? sources? ECU? non vtec to vtec? need alot of help people! luv u all
Old 11-02-2004, 01:47 AM
Wilson
Wilson's Avatar
Default please rply to me... peepz>>>
plz......
Old 11-02-2004, 04:26 AM
davidnyc
HC Competitor
davidnyc's Avatar
Originally Posted by Wilson
plz......
Most people on this board (I am assuming) are from the U.S. and have no idea what kind of car is a Rover or has ever seen one. You may get better help on U.K. specific Rover boards?
Old 11-02-2004, 04:38 AM
Wilson
Wilson's Avatar
but it has a d16a6 honda engine in it tho! its very similar to a 94 civic coupe basically, is a d to b series possible in a civic coupe then?
any other info>? thanks anyways,
il post some picture of my car asap! when im home, as im working at the moment,
Old 11-02-2004, 04:52 AM
pomansouth
pomansouth's Avatar
well let me start out this way, anything is possible with enough money but , you say it has a d-series in it huh. is it a obd1 car?? if so with a obd1 d series, i think the mount points are the same so you should infact be able to do that swap. You may want to put up a post in the civic forum since there is ALOT more traffic in there. Do that and see what others have to say.
Old 11-02-2004, 05:01 AM
Wilson
Wilson's Avatar
i wudnt know wot a obd1 car is dude! but i know the stock bhp of the my car is 108. with a d16a6 honda engine under the hood. ok i will post it in the civic forum thanks.
you have tell me what that obd1 car is man: (
Old 11-02-2004, 06:49 AM
George Knighton
George Knighton's Avatar
You seem mostly concerned w/the physical dimensions and motor mounts.
You will not have a problem with those if you are already able to fit a D16 into it.
I am assuming that the Rover you have is one of those little ones built in cooperation with Honda, anyway.
You know...like the one Richard Bucket (Hyacinth's husband) drives.
Old 11-02-2004, 09:21 AM
Rene M
Austin Texas
Rene M's Avatar
If it all ready had a D16 in it all you would need is a set of say B series CRX mounts and you can drop a B series in the car. Use a set of 91 teg axles, get a obd1 conversion harness and a Hondata ecu and it should work.. Sounds like fun i wish you were closer. I love swaps..I am dropping a RX-7 12a in a Spitfire right now and we are dropping a SHO v-6 in the back of a 911 to make a real mid engine as well. For pics look at out CRC site..
Old 11-02-2004, 02:57 PM
nightrider00R
nightrider00R's Avatar
i suggest you post in the hybrid forum as you may get more help.
Old 11-02-2004, 07:54 PM
George Knighton
Originally Posted by Rene M
I am dropping a RX-7 12a in a Spitfire right now...
Just the motor, or suspension and everything like the flared fender GRM Spitfire?
