Dash Removal for 94 Accord--help!
Old 12-23-2003, 10:16 AM
MDork
MDork's Avatar
Default Dash Removal for 94 Accord--help!
anyone have a write-up or some tips for removing the dash on my 94 coupe? will airbag be an issue? thanks--
Old 12-23-2003, 11:29 AM
KjG8erZ8
Black CD5 Sedan
KjG8erZ8's Avatar
Here's cryogens how-to on installing indiglos, but in the process shows you how to take the dash apart..
http://www.andrews.edu/~johnsonm/howto/indiglos.html
Old 12-23-2003, 01:00 PM
MDork
MDork's Avatar
hmm...thats a good start. actually im looking to remove the entire top half (not just the gauge cluster) so that i can dye it black.
also...to get to the screws i just pop off the buttons (cruise, defrost, etc)?
im such a n00b :P
Old 12-23-2003, 01:01 PM
04civicEX
04civicEX's Avatar
the best thing to do is go get the haynes manual for your car, it shows you exactly where every bolt is. thats what i did when i put my indiglo's in
Old 12-23-2003, 01:04 PM
I Like JDM
JDM Spec Tuner
I Like JDM's Avatar
If you want to move the top dash part, you got to take out the passenger airbag..To get access to the 4 bolts for the airbag you got to remove the glove compartment.
Old 12-23-2003, 01:16 PM
MDork
MDork's Avatar
this is getting overly complicated....ill get a haynes tho...thanks for the help
Old 12-23-2003, 02:32 PM
KjG8erZ8
Black CD5 Sedan
KjG8erZ8's Avatar
Oh ok, I wasn't sure if you just meant the the dash trim or not. In that case, yea you will have to mess with the airbag.
And about getting to the screws you will need to just stick a flat head underneath the buttons and it will just pop out to where you can reach the screws.
Old 12-23-2003, 07:12 PM
MDork
MDork's Avatar
maybe ill just go ghetto style and dye it in place....i dont wanna get jacked by the airbag
Old 12-24-2003, 03:22 AM
Casstrho
Casstrho's Avatar
Might sound stupid buy what do u use to dye ur dashboard?
Old 12-24-2003, 06:31 AM
Klatu
Klatu's Avatar
you can unplug the airbag control. it's behind the center console i think. look for a steering wheel exchange diy and it should tell you how to unplug the srs
