Auto Lude Tranny
WEEEEE!!!!!
Auto Lude Tranny
Prolly a repost, but if it is, please link. Would a Lude auto tranny with shifttronic (or honda varient of it) bolt directly onto an F23A block that is already auto?
THE RED 6th GEN Coupe
I can't imagine this being as easy as placing an F23/H22 manual on and H22 or F23 block.
You will need to see how the shifter in the cabin would need attached (no sport shift for Accord-would Acura TL fit?) likely needs an ECU swap or piggy back of some time, and it may require axel swapping/inter changing to some degree.
Is the prelude a 5speed or 4speed model?
It may prove to be much cheaper and better to install an Auto tranny cooler and modified/aftermarket torque converter into your stock 98-02 Accord 4-cyl tranny.
If the car is a 6-cyl I'd look at doing a base TL-Engine tranny swap as it would be a cheaper alternative to prelude tranny or full on type-S swap. Or do the cooler/torque converter mod as well.
WEEEEE!!!!!
hmm.. Neber thought about the troque converter, thats a good idea. Oh, thax for the ealier feed back about the sways from a tl-s. ordering mine as soon as I get X-mas money
cb7 fanatic
Originally posted by MrChad
You sure he swapped automatics?
Running lude manuals on cords is common, but only for manuals.
I think Level 10 makes after market tranny parts:
Torque converters and coolers, I'm not sure anyone makes firmer shift kits or beefed internals for auto-imports like the old dog muscle cars have.
Former H22 Accord Owner
a 97+ SS tranny is POS, even if you can figure out how to wire it in, your better of with a H23 auto tranny. besides the gearing will not be great for gas mileage.
honestly, learn how to drive stick and swap to manual. it's better and cheaper.
