New pedals
New pedals
The clutch pad in my '98 Integra has been worn right down to the pedal, and with the rainy season coming up quick, I'd like to know if anyone has any experience with a good pedal set. Thanks.
the carbon fiber sparco ones come with grip tape...for more grip. you can buy some from a skate shop and stick them on any pedal if you wanted. i dont know if its gunna look very nice though.you probably only need a strip on top of the pedal and at the bottom.
Not sure if grip tape is the stuff to get. It seems like it might interfere with the slip action. Assuming that all of you guys slip with your ankles instead of moving your entire leg back and forth.
You can take off the stock rubber piece, and put the grip tape from the skate shop on the flat metal piece, and then buy a new rubber piece to cover the grip tape when its not raining...just a suggestion though....:dunno:
DB Squad
Integra Forum Moderator
DB Squad
