type s engine codes
Old 08-12-2008, 12:15 PM
gsr converters
gsr converters's Avatar
Default type s engine codes
are the engine codes in the type s the same or does it change in 2005? if so what are the differences. thanks
Old 08-27-2008, 05:24 PM
Snoopy
been there done that
Snoopy's Avatar
the type s went to the k20z1 in 05. as for the differences, the hell if i know.
Old 08-28-2008, 01:08 PM
sherwood
I missed Sean
sherwood's Avatar
IIRC the only major difference was the cams, maybe some other stuff like exhaust changed. Overall the engine makes a little more power, said to be somewhere between the 02-04 type-s and the ITR
Old 08-31-2008, 06:44 AM
Stealth_RSX-S
Stealth_RSX-S's Avatar
The 02-04 RSX-S has 200hp at 7400rpm and 142lb of torque at 6000rpm. The 05-06 has 201hp (some say 210hp but thats false) at 7800rpm and 143lb of torque at 7000rpm. So the readings is one for each measurement, also with a higher rpm peak power for both readings, making the 05-06 slightly faster.
Old 08-31-2008, 09:42 AM
sherwood
I missed Sean
sherwood's Avatar
:bs:
The 05+ was rated using the new SAE measurements the increase wasn't that apparent in the numbers. Compared to the 02-04 engines the increase would have been to 210HP under the old system of measurement.
The 05+ engine pretty much was designed to be smack between the ITR and original Type-S engines.
