My GSR NA Rebuild
Old 06-23-2008, 10:45 PM
2001TEGGSR
2001TEGGSR's Avatar
In response to your question about compression, that should be completely safe in the hands of a good tuner.
I have no first hand experience with thin head gaskets, I've always tried to stay OEM in that dept.
Personally, I would explore all other possible options to raise compression, and use a 2 layer as a last resort. You can use flat faced valves, slightly mill the head, block, or both. Hell, a resurface might give you the bump your looking for.
Take more pics and post them as it comes together! I'm kicking myself for not documenting my build better, would have saved a lot of headaches.
Old 06-23-2008, 11:17 PM
jesusublime99
jesusublime99's Avatar
Here is my 64mm GSR throttle body I received from Maxbore.com next to a stock GSR TB. Turnaround time was 2 weeks from Florida to SoCal. I like all these modifications because my engine bay will still look completely stock.
File Type: jpg
Old 04-28-2009, 02:10 AM
jesusublime99
Well, I finally restarted the project after 1 year and here are some progress pictures (I hate having to stop to take a picture, so they're not great):
Doing all the work in my garage straight from the Helms.
Just installed ARP head studs, OEM headgasket, cylinder head & CTR camshafts. Along with about 20 or 30 oem parts that the Helms tells you to replace:
This was just after I finished doing my timing belt and valve adjustment with this great $17 tool:
New 96+ timimg belt lower cover for the ITR oil pump attached to Spoon oil pan, new valve cover gasket set along with almost all new Honda bolts. New oem crank pulley will be installed soon:
New BDL billet cam seal, and removed the VTEC solenoid to replace the filter.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 04-28-2009, 12:00 PM
Spec R
Spec R's Avatar
siiick good to see you back
DB Squad
Integra Forum Moderator
Old 04-28-2009, 01:23 PM
pslsnakes
F#%K JDM, USDM FTW
pslsnakes's Avatar
Nice build.. I will be doing a similar build. But I'll be using a set of agressive cams, ITR LMA's, dual valve springs, titanium retainers, a fully ported head, shaved head for bumped compression, etc.
As for tuning, I would reccomend getting an OBD1 ECU chipped, and have a tuner street and dyno tune it. It will be cheaper than that crap Hondata. Neptune, eCtune, and Neptune RTP is great.
Old 04-28-2009, 06:34 PM
jesusublime99
Thanks guys. The head received a basic port & polish as well as the intake manifold. This will be tuned by one of the best tuners in the country, Church Engineering.
They recommend I use Hondata S100, so I wont question them.
Old 05-02-2009, 04:02 AM
jesusublime99
Installed the IM today.Pictures are Thermoblock gasket from Outlaw Engineering, the ported intake ports, ported TB, and almost complete assembly:
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 05-02-2009, 06:43 AM
Spec R
Spec R's Avatar
wow, that porting looks great
DB Squad
Old 05-02-2009, 06:08 PM
Khazzy
The know nothing kid.
Khazzy's Avatar
holy sweet shiney goodies, more more more
Old 05-03-2009, 12:27 AM
pslsnakes
F#%K JDM, USDM FTW
pslsnakes's Avatar
Port job looks good. But why, why in the hell would you keep the junk ass stock GSR intake manifold?
