ls crank in a b16
Old 09-28-2003, 08:16 PM
davetec
davetec's Avatar
Default ls crank in a b16
i was wondering can a ls acura crank go into a b16a civic and would it be more of a stroke and what all what would i have to do to replace the crank
Old 09-29-2003, 01:27 AM
Kai
Rotorphile.
Kai's Avatar
No.
Unless of course you get custom length rods, which would cost more then your entire engine.
Old 09-29-2003, 04:34 AM
AwwsChwA
AwwsChwA's Avatar
why would you put an LS crank into a B16 anyway? The ONLY thing that makes a B16 put out any power is it's high redline. Put in a crank with a longer stroke and you'll drop that redline. It's already called the Torqueless Wonder for good reason. It would be the Gutless Wonder with a longer stroke.
Old 09-29-2003, 07:12 PM
JDMilan
JDMilan's Avatar
he is looking for more displacement via longer stroke, if you want a 1.8 liter motor just buy a used GSR bottom or build properly an lsvtec.
the deck height of the b16 and b18's are different.
Old 09-29-2003, 07:49 PM
Kai
Rotorphile.
Kai's Avatar
9mm, to be exact.
