difference between B16B, B16A, B16A2, B16A6...
Old 02-23-2004, 11:09 AM
jp184
jp184's Avatar
Default difference between B16B, B16A, B16A2, B16A6...
Hi, which are the differences mecanic between these engines?
B16A 150hp
B16A2 160hp
B16A4.5.6 170hp
B16B 185hp
Thanks
Old 02-23-2004, 12:06 PM
ludeboom
ludeboom's Avatar
not much of a b guy but here goes.
b16a - 1st gen VTEC - obd1
b16a2 - 2nd gen VTEC, higher CR?, obd2
b16a4.5.6 - no idea
b16b - CTR cams and pistons
pretty sure its all same block except for 1st gen b16a which may be closed deck.
~boom
Old 02-23-2004, 02:18 PM
dom93hatch
more meat, more fire
dom93hatch's Avatar
B16A came with cable tranny, while the A2 and B came with a hydro tranny.
Haven't heard of B16A4,5 and 6 though. Euro motors maybe?
Old 02-27-2004, 12:44 PM
jp184
jp184's Avatar
I wanted to know what was different between 150hp, 160hp, 170hp and 185hp of B16x.
Old 02-27-2004, 01:13 PM
MrFatbooty
Wannabe yuppie
MrFatbooty's Avatar
The 150, 160 and 170 hp versions (all B16Ax) are essentially identical. The 170 hp version has a slightly higher compression ratio due to different pistons. The 160 hp version is identical to what was sold here in the del Sol VTEC and the '99-'00 Civic Si. The 150 hp version is identical mechanically but has a lower-powered ECU tune for use with an automatic transmission.
The B16B is vastly different. The block is from a B18C but with a shortened stroke, and the pistons produce a very high compression ratio. The head is the same as a B18C5 in that it's a PR3 (B16A, B17A) casting with a port/polish job, more aggressive cams and stiffer valve springs. Early B18C5 heads have a slightly different intake cam. It shares its intake manifold and throttle with the B18C5 as well. Essentially it's a later B18C5 with different crank, rods and pistons.
Old 03-04-2004, 11:25 AM
jp184
jp184's Avatar
Thanks
it's what I wanted to know (I have a French B16A2 160Hp at 7600 and rev limit 8400)
Old 03-04-2004, 12:48 PM
ludeboom
ludeboom's Avatar
which are closed deck and which are open deck
~boom
Old 03-05-2004, 12:48 PM
Snoopy
been there done that
Snoopy's Avatar
~boom
they're all open
Old 03-07-2004, 10:12 PM
toanhung
toanhung's Avatar
B16A 150hp
B16A2 160hp
B16A4.5.6 170hp
B16B 185hp
Thanks
B16a SiR1 160Hp JDM SIR
B16a2 160Hp USDM 99 si
B16a3 160Hp USDM Del-so DOHC Vtec
B16a SiR2 170Hp JDM SIR2 Bigger Cams. Higher Cr
b16B 185Hp JDM Civic Type R Port n Polish, Higher Cr, Bigger Cam and better Valve Train
Old 03-08-2004, 12:50 PM
qtiger
qtiger's Avatar
~boom
AFAIK no B or D series engine has ever been closed deck.
Quick Reply: difference between B16B, B16A, B16A2, B16A6...
