How To: Clean Your Throttle Body
Old 09-22-2003, 04:38 PM
xplode
xplode's Avatar
your car was off and warmed up when you did it? or did u let it go on a cold engine, and also... idd you let it sit 5 mins or just hook it back up and go/
Old 09-24-2003, 10:21 PM
b12uceHuy
Jizz Maste12
b12uceHuy's Avatar
my car was on when i did it and the engine was COLD... after i pure 1/3 of the bottle in to the TB i turned off the engine. Let it set fo 5-6 mins then took a spin around the block then into the street WOT.
Old 09-24-2003, 10:24 PM
b12uceHuy
Jizz Maste12
b12uceHuy's Avatar
I did my friends 94 accord and when I place the straw into the TB plate it rev the engine to high so what we did was inject the sea foam then start the engine (so the liquid would be sucked into the TB) did that 8 times, then let it sit for 5-6mins. Took a spin on the freeway WOT. could be done both ways
*** just dont pour it liquid all at once into the TB or you'll hydo lock your engine ***
take your time
Old 09-27-2003, 10:01 PM
YeaItsAFourDoor
..::-Free your mind-::..
YeaItsAFourDoor's Avatar
I agree on the bottle from autozone...
Old 10-01-2003, 11:51 PM
Samson
chris is the devil
Samson's Avatar
i did this with the STP spray... and my car now has an idle surging problem... dont ask me what caused it... everything is installed correctly.
Old 10-02-2003, 03:39 PM
YeaItsAFourDoor
YOU DID IT WRONG, YOUR CAR IS GONNA DIE!
Old 11-06-2003, 09:02 PM
klikster
klikster's Avatar
You F'd up your MAP Sensor. h:
Some Carb/TB cleaner will mess it up. Is your CEL (check engine light) on?
Old 11-22-2005, 07:09 PM
FallenAngelHIM
FallenAngelHIM's Avatar
BUMP! can someone update the pictures? they don't seem to be "available at this time" what's it doing, taking a shit?
Old 11-22-2005, 08:33 PM
dank24
dank24's Avatar
Yea , it's sapose to go in the brake booster line.
Old 06-22-2006, 09:00 PM
b12uceHuy
Jizz Maste12
b12uceHuy's Avatar
I just cleaned my TB again this weekend and updated with new pictures.
