tinting/smoking Tail lights , Quick Question..
Old 05-04-2006, 06:04 AM
haris2887
haris2887's Avatar
Default tinting/smoking Tail lights , Quick Question..
hi,
i tinted my tail lights the other day and they turned out great, i sprayed clear coat on top as well to get it to shine like OEM finish...
now i have figured out that they are not Dark enough for me, i want to tint them more....
please tell me what method should i use ....
a) just add some more tintspray on top or the clear coat, and let it dry, and then add clear coat once its dry ...
b) sand the tail light (lightly ) first , with like 1000 grit sand paper and then use a plastic primer and then the tint spray to tint them , and finally add the clear coaat....
c) other please Specify ....
Old 01-22-2007, 08:21 AM
slintegra
slintegra's Avatar
u should be able to tint over the clear coat
Old 01-22-2007, 03:52 PM
aznpimpin89
aznpimpin89's Avatar
I'm planning on tinting my tail lights. Did you sand your taillights first, then paint it? Or did you just clean the tailight with water and soap and and then paint it?
Old 01-26-2007, 10:18 AM
slintegra
slintegra's Avatar
when i tinted the taillights on my 96 civic before i crashed it i just cleaned and tinted..... use light coats
Old 07-24-2007, 06:20 PM
88_rex_si
88_rex_si's Avatar
Originally Posted by haris2887
hi,
what kind of tinit paint , and where can i get some
Old 07-25-2007, 08:07 AM
finch13
finch13's Avatar
are you painting the interior or exterior of the lens? If the exterior i would paint it like a body part: lightly sand out scratches, tint, wet sand the tint lightly, 2x clear. otherwise, paint the interior if you can and just wash it with soap and water and tint away.
Old 08-04-2007, 08:35 PM
ironscepter
ironscepter's Avatar
that's what i know as well -- 1000 grit then tint spray...
Old 09-20-2007, 12:46 AM
zharra
zharra's Avatar
I'm just wondering if I could do the same on my honda headlight ?
Old 09-20-2007, 11:37 AM
pnthr30
pnthr30's Avatar
Or, you could just go to a frabric store and get some thin gauge smoked vinyl, go at it with a heat gun and some rubbing alcohol and you would have a tint you could take off. Just another way to skin the cat.
Old 10-15-2007, 10:42 PM
dranom
dranom's Avatar
can you just baked the tail light like a headlight?
ive done 5 cars w/ baked headlights and i was wondering if i can do it w/ tail lights too?
