Accord
Sponsored by:
Sponsored by:
Need help diagnosing a problem
Old 06-20-2008, 08:16 AM
Skelly_GSR
RB does men
Skelly_GSR's Avatar
Default Need help diagnosing a problem
- When I am on the throttle it almost sounds like a piece of my cat is broken and rolling around in my exhaust. It only makes this noise on low rpm's. If I go over 3.5k the noise will go away.
A friend at work said my resonator may be falling apart internally. He recommended a take a big screw and drill through it to keep everything tight. The noise if fucking annoying halp h:
Old 06-20-2008, 08:55 AM
JimBlake
JimBlake's Avatar
What kind of car?
Rattling heat shield on the catalyst?
Some Hondas have problems with a 'buzzing' A-pipe (from the manifold to the catalyst). It's a pipe-inside-a-pipe & the inside pipe can buzz against the outer one.
Old 06-21-2008, 08:35 PM
CSVT.UA.SHO
CSVT.UA.SHO's Avatar
or by a slight chance it could be a broken-down cat.
I had a nissan stanza that had similar symptoms and it turned out to be the cat.
can't say for sure though..
