Honda Accord 2.0 I 1993 Please Help Me !!!!
Old 07-26-2007, 10:52 AM
diverpaulo
diverpaulo's Avatar
Default Honda Accord 2.0 I 1993 Please Help Me !!!!
Hi, Im From Lisbon Portugal
Please Help Me, I Need To Change The Front Break Discs And The Pads From My Car, It Have Abs, How Can I Do It??
I Need To Replace The Hub Unit To When I Change The Break Discs???
Thanks A Lot !!!!!!!!!!!!!!!!
Where Can I Find A Technical Manual For It ?????
PLEASEEEEEEEEEEE I REALLY NEED THE HAYNES MANUAL FOR IT (DOWNLOAD IT )
Old 07-27-2007, 01:13 AM
diverpaulo
diverpaulo's Avatar
nowbody can help me ??????????????????
Old 07-27-2007, 11:13 AM
finch13
finch13's Avatar
I don't think any Haynes or Chiltons are downloadable. You could possibly order them online and have them shipped... As for the rotors, they are a bitch to change on the Accord. You have to take off the huge nut attached to the axle (34mm I believe) and then remove the castle nuts from the upper control arm, lower control arm, and the steering tie rod. Remove the whole hub assembly and take out the four 12mm bolts on the back of it. Hopefully the rotor will slide off. There might be a few more steps, since I've only removed the hub and attempted to take off the rotors.
Old 07-31-2007, 10:01 AM
diverpaulo
diverpaulo's Avatar
Thanks A Lot FINCH13
