engine swap---HELP!
Old 10-26-2011, 05:33 AM
id_w1ck3d
id_w1ck3d's Avatar
Default engine swap---HELP!
I Dropped a d15b jdm into my civic, it did have a y7.. im having a distributor problem.. my y7 wont work and the one that came on the d15b wont work.. what do i do?? please help..
im new to this and not a mechanic, please be nice...i dont care about hp or tq.i just want my car to run again!
Old 10-26-2011, 05:37 AM
id_w1ck3d
id_w1ck3d's Avatar
neither engine is vtec
Old 10-26-2011, 10:01 AM
id_w1ck3d
id_w1ck3d's Avatar
i need some info please
Old 10-26-2011, 12:19 PM
Line7
Platinum Member
Line7's Avatar
im not sure if the y7 distributor is compatible with the d15b, but maybe you can fix the distributor that came with the d15b. If the dizzy is not giving you spark its either the coil or the igniter unit. Dont replace those just test them first, there are how to videos on youtube. But before that I would take the dizzy cap off and file down the metal terminals with a flat file and also the metal contact points on the dizzy rotor.
Old 10-26-2011, 02:42 PM
Civic2Scooby
Civic2Scooby's Avatar
yup, test coil and ignitor on both..if you have one good in each, frankenstein a good dizzy
Old 10-26-2011, 07:05 PM
id_w1ck3d
id_w1ck3d's Avatar
i have checked both. they are both good. even the dizzy that came on the jdm d15b wont let it fire.. the plugs get spark but the car wont turn over.. i asked everyone i know. no one has a clue....
Old 10-27-2011, 04:56 AM
Civic2Scooby
So you do get spark, then not a dizzy problem. Fuel and compression are the next checks.
Old 10-27-2011, 10:19 AM
id_w1ck3d
id_w1ck3d's Avatar
yes theres spark...it trys to turn over when is really retarded..but cant turn it for enough
Old 10-27-2011, 02:30 PM
Line7
Platinum Member
Line7's Avatar
take fuel line off from rail, turn key to on position, if fuel doesnt come out when pump primes then check ecu ground, fuel pump, etc. if fuel comes out, check compression/t-belt.
Old 10-27-2011, 09:07 PM
id_w1ck3d
id_w1ck3d's Avatar
its getting fuel.. when i pulled plugs to check compression they had fuel on them.. is it possible dizzy is not compatable?
