When does VTEC engage on my D16Y8?
Old 11-25-2005, 04:28 PM
Sleeper Honda
Sleeper Honda's Avatar
Default When does VTEC engage on my D16Y8?
when does D16Y8 SOHC VTEC engages its VTEC? my redline is 6800.
thank you
Old 11-25-2005, 07:17 PM
kmh_RED
kmh_RED's Avatar
well my friend has that engien and his kicks into v-tec at 5200 rpms
Old 11-25-2005, 07:43 PM
1995Civic
I hate ricers
1995Civic's Avatar
It should be about 4800, but im not 100% sure on that. I also have a z6 and that might be a little different...
Old 11-25-2005, 09:06 PM
thomas
pew pew pew
thomas's Avatar
i dont hear vtec till like 5600 deff not 4800
Old 11-26-2005, 12:19 AM
CaliDELSOL93si
CaliDELSOL93si's Avatar
you don't "hear" vtec. you "hear" the butterfly valves (secondaries) opening. primaries open way before that. D16z6 is near the same as the D16Y8 at 4800 RPM's with secondaries at 5200 RPMS
Old 11-26-2005, 02:48 AM
Sleeper Honda
ok. cool. thanks guys. that really helps. now do you consider having a V-AFC a Must? and how soon do you prefer to engage your VTEC?
Old 11-26-2005, 06:19 AM
1995Civic
I hate ricers
1995Civic's Avatar
Thank you.
I guess i was way out of line to think 4800 huh?...ha
Old 11-26-2005, 10:23 AM
lilriceburner
>94' Civic Si Coupe
lilriceburner's Avatar
Well, before i asked i just made a VTEC Light to be sure because i got a lot of diffrent responses. I have a d16z6 and my VTEC kicks in at 4800 RPMs. I made a vtec light for my buddy that had a y8 and his went in at 5500 RPMs.
Old 11-26-2005, 11:13 AM
CaliDELSOL93si
i wouldn't spend the money on a VAFC, i would just spend the money towards a hondata s200 w/o boost for maybe $275 and get it tuned to perfection, then you never have to worry about it again. Having a vtec controller does nothing, because you want your engine tuned so when your lower cams stop making power, then the butterfly valves open up and higher cams take over. You want the perfect interchange which can really only be done with good quality tuning !!! good luck
Old 11-26-2005, 12:58 PM
thomas
pew pew pew
thomas's Avatar
i think that the only butterfly is on the throttle body and opens with the gas pedal not with vtec
and like i said the vtec on a y8 is 5500-5600
Quick Reply: When does VTEC engage on my D16Y8?
