'00 SI Rim weight???
Old 02-12-2005, 11:04 AM
00CivicSleeper
Just Beginning...
00CivicSleeper's Avatar
Default '00 SI Rim weight???
Hey,
Does anyone know the weight of 2000 civic SI rims? Also, im running on EX hubcaps right now, if I get the si rims, will i notice a difference in acceleration/speed?
Old 02-12-2005, 04:38 PM
CivicSiRacer
Honorary Moderator Alumni
CivicSiRacer's Avatar
about 15lbs.
Autocross Help Page
Old 02-12-2005, 04:48 PM
chimchim
WRX cuz Honda won't wagon
chimchim's Avatar
I have an EX and went from stock 14" steelies to Si 15". Feels slightly worse acceleration, but very noticeble improvements in reduced body roll and grip. Granted, when I upgraded to Si wheels, I also put better rubber on.
Old 02-12-2005, 05:48 PM
CivicSiRacer
Well the worse acceleration could be from the wrong tires size. You will not notice a difference from a 14lb steel wheel to a 15lb Si wheel. If you can then you are a liar.
Autocross Help Page
Old 02-13-2005, 10:06 PM
chimchim
chimchim's Avatar
By "feel" I mean to be about as accurate as a butt dyno.
Old 02-14-2005, 04:29 AM
oldskoolcivic
oldskoolcivic's Avatar
i went from 16 lb 14' DX steelies (94 civic) to 13' 14 lb DX steelies (90 civic) and i noticed a pretty good difference in acceleration in first gear.
Old 02-14-2005, 08:21 AM
CivicSiRacer
If you can feel a difference between 16lbs and 14lbs then you are high on drugs.
Autocross Help Page
Old 02-14-2005, 08:39 AM
wilsel
wilsel's Avatar
I think the only difference you might feel is the tire width. going from 13's to 15's will increase your tire width, and slow down acceleration. It will improve handling which to me is more important. Not to mention you should be using a shorter sidewall which will decrease roll, and feel more stable.
Old 02-14-2005, 09:00 AM
chimchim
chimchim's Avatar
But tire and rims go hand in hand. If you +n or -n (too keep approx wheel diameter), you change the weight of the wheel which has a different mass and inertial. Multiply that by 4 and considering that it's a rotation mass, I'd say people familar with their cars probably feel "something different" but probably can't tell exactly if it's worse or better. People say 2lbs off the flywheel makes a huge difference.
I'm not saying it's an accurate feeling.
So in summary:
- can you feel it? maybe
- can you identify a help/hinderance? probably not
- will it affect gas mileage? depends on tires too
- will it affect 0-60 times? depends on tires too
Old 02-14-2005, 09:14 AM
00CivicSleeper
Just Beginning...
i know i asked this in another thread, but are hankook radial k106's any good?
