Running axle without dynamic damper Q..
When I did my left axle on my 92 4dr LX 5 speed, Autozone gave me an axle without a dynamic damper. They said it would work, the rebuilders must have changed and eliminated it.
Would this cause the differential bearing to fail?
There's a lot of play in the bearing up and down and it makes one hell of a clunk when turning right and hitting a bump (pulling into a driveway that's raised above the road surface).
I just purchased axles minus the dampers too. What did you end up doing? It looks like you can tear them apart and insert the damper but it seems a shame to tear apart a perfectly good axle!
On permanent hiatus
dont need it
The differential problem is probably unrelated. Stray away from autozone axles, though. They are complete shit. You are probably experiencing a blown CV joint.
On permanent hiatus
Originally Posted by xpman
What would make Autozone axles inferior? Anybody have any problems with them?
On permanent hiatus
I have always had good luck with autozone axles...though it could be just that, luck.
