1997 Honda Civic LX (Oklahoma)
6 Attachment(s)
This is a 1997 Honda Civic LX with a manual transmission.
I just replaced the front rotors and pads and both C V Joints less than 1000 miles ago. I replaced all 4 struts and springs less than 4000 miles ago. It has 4 Acura Integra rims with 2 fairly new tires on the front and the back 2 are still in good condition. It has sun visors but they are in need of changing. The car drives very smooth and is a good reliable car. The idle control valve is dirty so it idles a little low but its not bad, just needs to be cleaned. The check engine light comes on since the car is missing an O2 sensor (I couldn't remove the sensor from the stock manifold). I just did a tune up on it less than a month ago with a new ignition coil, distributor cap, spark plugs and plug wires. These are some specs on the car: 147000 miles Power Steering Power Windows Power Locks Power Mirrors Cruise Control Am/Fm Tape Deck (tape deck not functional but the car will come with an F.M. transmitter for use with any MP3 player.) Cross drilled and slotted rotors with semi-metallic pads Type-R shift knob Header with full exhaust Shorty air filter (comes with a cold air tube add on, just not installed) Rear sub-woofer wires kit installed (no system currently in place) Stock intake manifold, shift knob and air filter box available if wanted Asking $3500 or best reasonable offer. Please contact Allen at letmexplane@yahoo.com or 405/714-6065 |
