1988 CRX SI FS/FT Fremont, Ca
Old Feb 27, 2009 | 03:10 PM
psychoblue23's Avatar
psychoblue23
Default 1988 CRX SI FS/FT Fremont, Ca
SOLD!!!!!!!!!!!!!!!!!!!!!!!!!!
Also willing to take trades: As stock as possible
90+ 4 door accord
92+ civic
basically looking for something with 4 seats, carry the kid around
Car info: passes smog, i just smogged in 08, reg is due now and i don't feel like paying since im selling so you can take it out of the cost of the car.
Car was purchased in 2007 from a friend. I have owned it since and put maybe 6 or 7 thousand miles on it. i dont drive it very often. The car runs great, has had lots of work done, but still needs some TLC. I am looking for a more "family" orientated vehicle so this 2 seater has to go. Car has 250K miles on the chassis but was replaced with a sohc zc in 07 that had 83K miles. so technically motor still has under 100k and all the stuff was replaced timing belt water pump etc when the motor was swapped. Car had a non working ac so i removed it, but the wiring is still in place so if you decided to source parts its still basically plug and play for the a/c.
The good:
New parts
Front Hawk HP+ Pads
New front rotors
New lower balljoints
Brand New oem upper control arm including bushings and balljoints
New oem outer tie rods
New inner tie rods (not installed)
ES front lca bushings
ES front sway bar bushings
ES shifter stabilizer bushings (not installed)
ES shifter arm bushings
new OEM engine mounts Pass/Driver installed front and rear NOT installed
Prothane poly inserts
New dizzy o-ring
VC gasket
Oil Pan gasket
Axle seals (not installed)
Axle nuts
new spark plugs NGK
Powder coated Satin Black VC from
Valve cover grommets
Spark plug tube seals
K&N Drop in filter
Momo copy steering wheel with real MOMO hub adapter
Mfactory Steel weighted shift knob (type r replica)
Used parts included with purchase:
Rear 89+ lca's with ES control arm bushings installed never installed
GSR Black Cloth seats Driver perfect passenger one small hole
EG climate control to replace crappy CRX unit
Issues with car:
Currently there is no stock pass seat, thats why I have the GSR's
EG climate control needs to be wired up
Front shocks are oem I am assuming they are no good, rears are GR2's
Rear spring driver side is cracked ( I have been driving on it for a year)
Glove box lock is broken
Driver door panel is peeling
Timing is off, when i replaced Dizzy o-ring i didnt do it.
Sun roof tracks are dried.. So soemtimes it gets stuck popped up in one corner. I am too lazy to take it off and clean and grease it up. i replaced a rusted one with a newer white one.
horn needs to be wired up
Dimmer switch just stopped working so the dash lights wont light up til you get it replaced from junkyard
Pictures:
here you can see the sunroof popped up cuz it gets stuck
Old Mar 2, 2009 | 07:15 AM
psychoblue23
Tough time to sell. Priced dropped to $1400 found a truck, need down payment money
Old Mar 12, 2009 | 11:52 AM
psychoblue23
$1200!! Buy me!!
Old Mar 14, 2009 | 05:11 PM
psychoblue23
Sold! $1200
