FS: 1993 Honda Del Sol Si - Turbo in Maryland
Old Oct 11, 2006 | 05:10 PM
StreetRacin101's Avatar
StreetRacin101
Default FS: 1993 Honda Del Sol Si - Turbo in Maryland
I currently have the vehicle up on eBay, but am willing to sell outside of ebay if anyone is interested in it. If you have questions, great. If you want to make an offer, great. Please no flames, no low balling. If you just want to bid.. http://cgi.ebay.com/ebaymotors...76795
The motor was built up and turbocharged, along with many other modifications performed. She is estimated at 225hp, runs 10psi, and is running an Uberdata engine managment setup, so she is upgradable even still!
The following are a list of some of the upgrades on this vehicle:
Motor has been built with:
DSM T-25 Turbo
Equal Length Stainless Steel Tubular Manifold
31x6 Bar-Fin Intercooler
Heat Wrapped Piping
Vacuum Manifold Block
Eagle Extreme H-Beam Rods
ARP Head Studs and Rod Bolts
SRP 8.5:1 Pistons (Intended for 15+ psi)
MLS Head Gasket
Hondata Intake Manifold Gasket
450cc High Impedence Injectors
Walbro 255lph Fuel Pump
B&M Adj. Fuel Pressure Regulator
MSD Extreme Distributor Cap
Magnecore Spark Plug Wires
1 Step Colder NGK R Spark Plugs
ACT "Stage 2" Clutch
Oil Catch Can System w/ PVC Bypass
Thicker-core Radiator Upgrade
Silicone Radiator Hoses
Moroso 5.5qt Oil Pan
Moroso Oil Pickup
Fidanza Adj. Cam Gear
ECU equipped with Uberdata v1.66 and a 12psi tune
Plus More...
Suspension/Brakes has been upgraded with:
Apex Suspension Full Coilover Setup
SPC Front Camber Joints
Front Upper Strut Brace
Rear Upper Strut Brace
Front Lower H-Brace
Rear Lower Strut Brace
Fastbrakes Original Front & Rear Big Brake Upgrade Kit
Wheels:
17x7 TenzoR Sinko-R Wheels (White) Qty: 5
Yokohama Parada Spec-II Tires 205/45ZR17
Polished Tuner Lug Nuts w/ Key
Extreior/Exhaust includes:
Vader 2 Rear Bumper
Kaminari Front Bumper and Side Skirts
Aerogear Low Profile Deck Spoiler
Dual Canister Exhaust w/ 2.5" Piping Back
High Flow Catalytic Converter
Custom Carbon/Kevlar Hood, Red Kevlar
Miscellaneous Accessories (which I will leave out a lot probably):
Short Throw Lever w/ Modified Height
Skunk2 Weighted Shift Knob
Tekniq Removable Steering Wheel Setup
Scat Racing Seats
Harness Bar/Roll Bar
Fiberglass Dash
Touchscreen LCD Rear View Mirror
Police Issue Strobe System
Full FAZE Gauge monitoring system
S7 Gauge Cluster system
Adjustable Shift Light
Code Alarm
And so so so much more.
Note, Some photos may show vertical doors. The vehicle no longer has vertical doors.
Vehicle has been featured at many shows, been in several magazines and tv shows, and has been sponsored for several years. I just dont have the time and energy that I had when I was younger for keeping up with the show/race scene. Time for someone else to carry on her legacy.
The areas that will need attention. There is a chip in the windshield that will cause it to need to be replaced. The power mirrors do not work, but are still adjustable manually, it was caused by ther vertical doors, and just one of the many reasons those door hinges were sold. The o2 sensor could probably stand to be replaced as well, its sending faulty readings to the air/fuel ratio gauge lately. The engine will need a new front main seal, its starting to leak oil from behind the crank pulley, and its not uncommon for that seal to be the cause. She still runs fine however.
Overall, the vehicle is in pretty good shape. There are the few dings from doors, a dimple on each fender from when it had vertical doors, and being she is 13+ years old, the paint is starting to get lighter on the plastic areas of the vehicle. Its not bad at all as you can tell from the photos. Just a shade off of the metal areas of the vehicle.
The rims do have some minor dents in their lip, but still balance out fine, and hold pressure with no problems at all. The vehicle even comes with a matching 5th wheel for a full size spare. Keep in mind, she would tour up and down the east coast for shows, so she has almost all highway miles.
Included Extras!!
I will be including extras with the vehicle, such as an upgraded Master Cylinder to increase braking power. Side Marker lamps that were to be installed in the fenders where the dimples are, to eliminate them and offer better visibility of the vehicle on the road. Other items such as a second steering wheel that works with the same system will be included, other aftermarket accessories, and more. Also, a set of modified aftermarket taillights will be included, AND MORE!
Because the vehicle is a custom built vehicle, it is being sold as-is. I am willing to deliver the vehicle within 50 miles of Bel Air, MD 21014. Winning bidder is responsible for all other delivery/pickup needs.
Old Oct 12, 2006 | 06:31 AM
StreetRacin101
ttt
Old Oct 12, 2006 | 06:08 PM
StreetRacin101
Old Oct 12, 2006 | 06:44 PM
beathookup's Avatar
beathookup
It's a JB thing
did this car used to have zebra style decals on it a while back
Old Oct 13, 2006 | 06:17 AM
StreetRacin101
Yes
Old Oct 16, 2006 | 08:09 AM
StreetRacin101
Old Oct 16, 2006 | 01:25 PM
eqmdh22's Avatar
eqmdh22
looing for trades
Old Oct 17, 2006 | 06:41 AM
StreetRacin101
May consider trades.
Old Oct 18, 2006 | 05:34 AM
StreetRacin101
Last day on auction!
Old Oct 19, 2006 | 05:57 PM
eqmdh22's Avatar
eqmdh22
i have jdm h22a for sale willing to trade plus cash
