I need help programing keyless remote
Old Dec 9, 2007 | 01:37 PM
bratprincebrad's Avatar
bratprincebrad
Default I need help programing keyless remote
I recently bought a 2007 Acura TSX. I also bought a key FOB that is for my model. However I cannot find directions to program it myself. Can anyone help?
Old Dec 9, 2007 | 08:49 PM
Grifter's Avatar
Grifter
try this
Originally Posted by bngu1
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors and the hatch are closed.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 1 to 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 1 to 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
12. YOU SHOULD NOW HAVE HEARD THE SOUND OF THE DOOR LOCK ACTUATORS! Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 10 sec., aim any remaining transmitters (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored. (OPTIONAL)
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Old Dec 17, 2007 | 07:52 AM
1764's Avatar
1764
Will this work with the 2006 TSX?
Old Dec 17, 2007 | 08:09 AM
Grifter's Avatar
Grifter
yes
Old Dec 17, 2007 | 08:13 AM
1764's Avatar
1764
Thank you!
