install Full Nose Mask
hi there,
I would like to install Full Nose Mask on my TSX 06...How Can i install myself..?? or it can be installed only by dealer?? pls advice..
thanks
thanks
where did you get it?
it should have come with instructions
otherwise here are some courtesy of handaaccessories
http://www.handaaccessories.com/tsx/08P35.pdf
how is it useless if it protects against road debris
I missed Sean
1 Post
even if you put it on and take it off (which tends to be a pita) alot of these kits tend to make the paint look uneven over time from rubbing, uneven wear, etc.
in my honest opinion it makes more sense to just let whats going to happen happen, and if anything you can get a clear bra
I would say your best option would be to get a clear bra for your TSX. All that rubbing and discoloration from the full nose mask will suck @$$. You can even buy the kits online from rockblocker.com and DIY.
