Initial impression of the Toyo T1-S
Old Sep 30, 2002 | 07:58 AM
DakarM's Avatar
DakarM
Default Initial impression of the Toyo T1-S
Mods if not appropriate for this forum please move to basement.
So I've put on approximately 600 miles now
2 trips to Sacramento and commuting with the car 75miles per day will do that in a week
The first 2 days I had the tire, they were quite noisy. At first I thought it was just because the tires were still new. I would take the freeway on-ramp at 45 and the rears sounded like squeeling pigs!
Saturday morning I checked the tire pressure on all for. The fronts were at 32psi the rears were at 32psi. Doh. I went down the gas station and increased them to 34 front and 35.5 rear. After that I drove to Sacramento.
Well what a difference a few pounds of air pressure makes The rears nolonger squeel like a pig The car as a whole has a lot more grip then it did the day before.
After about 500miles I did a quick start (about 1900~2000rpm take off) getting on the freeway and wow! With the dunflops I would have gotten mostly wheel spin. The Toyos just chirped for a sec and griped! Very impressive.
I can't wait til next weekend for the autoX now
I've gotten my SAG back which I was slowly losing for the past year or so
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old Sep 30, 2002 | 11:23 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
It takes about 500-1000 miles to get the coating off the tires. But yeah air pressure will make wonders on a tire.
Autocross Help Page
Old Sep 30, 2002 | 12:22 PM
DakarM's Avatar
DakarM
I should have about 1100miles before the autoX. I can't wait
LCD Squad #0001
Old Sep 30, 2002 | 04:51 PM
stephan's Avatar
stephan
:exnbp:
Where were the toyos purchased/
Old Sep 30, 2002 | 05:22 PM
rick's Avatar
rick
not noob?
from treadepot.com
but if are you looking to get some new tires I would also check out Bridgestone Potenza S-03 Pole Position.
http://www.tirerack.com/tires/Sizes....+Pole+Position
Most people seem to agree that the S-03s are one step ahead of the T1-S and the price is similar. The S-03s are about $10 less or so per tire right now.
For example: from tirerack.com S-03s 205/55WR15 $102
From treadepot.com Toyo T1-s 205/55R15 $ 119.00
I went with T1-S based on a friends recommendation who also had a M Coupe.
Old Oct 1, 2002 | 02:46 AM
CivicSiRacer
Don't know if you guys know the Speed World Challenge cars use them (shaved of course). I knew someone last year who tried them for autocross and he said they stuck pretty well, but for the price you could find cheaper tires.
Autocross Help Page
Old Oct 5, 2002 | 08:23 PM
VTEC's Avatar
VTEC
I was gonna do a tire comparo between 195/50-15 T-1S and S-03 at Buttonwillow during Hybrid Track Day #3, but unfortunately, a stubborn S-03 just did not want to mount on a Civic Si rim. The result? Scratched up Si rim (that was mint/perfect) and no comparo.
I have about 3000 miles on my set, and I will try to get an S-03 replacement so I can do a comparison at Hybrid Track Day #4 at Buttonwillow the day after Thanksgiving. I will try to get the S-03 mounted so I can drive around on them before taking it to the track.
But for the T-1S, my initial impression was that they were slow in turn in. Of course, 32psi front and rear was the culprit. I personally prefer quick turn-in characteristics, and use 42psi front and 38-40psi in the rear. On the way up to Buttonwillow (4hour drive), I increased the pressure and boy, it was night and day!
I am looking forward to this comparison...I hope I can get it done.
Old Oct 6, 2002 | 03:58 PM
rick's Avatar
rick
not noob?
The toyos did okay. Better then the stock dunlop 8080e but of course not as good as R-compounds
on saturday I was getting crazy understeering problems. a lot more then with the dunlops.
on the advice of a fellow m coupe driver i drop the rear to 32psi and left the fronts at 36psi.
oh boy night and day is right! there was still a bit of understeer but no where nearly as much. but on my las run i had a slight oversteering problem.
on sunday I set the pressure to 34rear and 38 front and that made the car much much happier.
at last I need more camber because this is what happened to the toyos
Old Oct 6, 2002 | 09:31 PM
VTEC's Avatar
VTEC
Are those the rears? Rear tires generally have that curling at the tread block edges. I don't get those on the fronts because I guess they get scrubbed out during hard driving.
Old Oct 6, 2002 | 09:48 PM
stephan's Avatar
stephan
:exnbp:
Looks like my front tires from this mornings autocross. Although I did rotate them last week. Are FWD's supposed to get those on the front or back? Or does it depend on teh camber settings?
