The World's most Poweful Piston Engine
Old May 6, 2003 | 07:10 AM
Hondaman's Avatar
Hondaman
Black Pearl
Default The World's most Poweful Piston Engine
The Wartsila NSD (Sulzer) RTA96-C two-stroke diesel engine is the most powerful and most efficient piston prime-mover in the world today. Bore just under
3'-2" and the Stroke is just over 8'-2". For those counting, that comes out to 1,333,722 cubic inches (read as: one million three hundred thousand plus!) for the twelve cylinder version!
Available in 6 through 12 cylinder versions (all inline). Engine weight exceeds 2,000 tons in the 12 cylinder version (the crankshaft alone exceeds 300 tons).
Point of maximum continuous power is 89,640 HP at 100rpm with the 12 cylinder version. Point of maximum fuel economy is 53,244 HP at 90 RPM. The 12-cylinder engine exceeded 100,000 horsepower during overspeed testing (all of 101.5rpm!) while under test at Japan's Diesel Union works (who built the first engines and from who these pictures are taken).
Fuel consumption at maximum power is 0.278 lbs/HP/hour (BSFC). Fuel consumption at maximum economy is 0.260 lbs per HP per hour.
At maximum economy the Sulzer engine exceeds 50% thermal efficiency i.e. more than 50% of the fuel going into the engine is converted to power) For comparison, consider that automotive and small aircraft spark-ignition engines have British Standard Fuel Consumption figures in the 0.40-0.60 lbs/HP/hour range and 25-30% thermal efficiency.
Even at its most efficient power setting, the Sulzer 12 cylinder consumes nearly 1,660 gallons of heavy fuel oil an hour.
Old May 6, 2003 | 07:21 AM
GSRacer's Avatar
GSRacer
Shadetree Mechanic
what the hell is it for?
Old May 6, 2003 | 07:26 AM
Motohip's Avatar
Motohip
That's Korean writing.
Old May 6, 2003 | 07:29 AM
Hondaman's Avatar
Hondaman
Black Pearl
I think it's probably used in big boats.
Old May 6, 2003 | 07:47 AM
The Beav's Avatar
The Beav
i
rotaries are better
Old May 6, 2003 | 07:57 AM
Deludedteg's Avatar
Deludedteg
dude turbo that bish!
spanky's Avatar
spanky
I go duffy on dem bitches
:repost:
Old May 6, 2003 | 08:07 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
Old May 6, 2003 | 08:11 AM
DakarM's Avatar
DakarM
:werd: I'm also wondering why an engine that is "tested" in Japan has two huge banners in korean?
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old May 6, 2003 | 08:18 AM
The Beav's Avatar
The Beav
i
