cb radio thread
Old Dec 26, 2009 | 03:20 PM
DarkStarr's Avatar
DarkStarr
Shake n Bake!
Default cb radio thread
anyone able to recommend a good cb with a range of 5-10 miles? i would like to mount this under my dash in the truck.. ~$100 a decent price?
Old Dec 26, 2009 | 04:15 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
I buy the Cobra line all the time for my wheeling rigs and they work just fine. You need to remember it isn't like a cell signal and will only broadcast dependent mostly on length of antennae and line of sight. You can bump up the power on some models to 12 watts+ and it will give you amazing range, but if you are caught by FCC (yes it happens still) you are in for a big fine so set it up on a switch if you go that route and make sure you get an antennae that won't glow too bright pushing that kind of power (yes they will literally glow with huge amounts of power).
I used to run a 30 watt setup in my truck when I was in Nebraska and was able to transmit about 40 miles reliably on average and bounced to 180 with the right conditions. It is fairly easy to surpass that but you really have to tune your gear to get that kind of range and not many can reply to you out that far, it is good for an SOS signal though if you are in the sticks.
Old Dec 26, 2009 | 04:19 PM
DarkStarr's Avatar
DarkStarr
Shake n Bake!
was waiting for your opinion, thanks. i was looking at a cobra but im not really sure which model i should get or what price range i should be in. im not looking to get as big of a range as what you described, but i was told of a cb radio shop some odd miles away from me that tunes antennas and whatnot..
Old Dec 26, 2009 | 04:23 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Meh you can do it yourself. Get an SWR meter from Rad Shack and hook it inline between the radio and the antannae. Read up on adjusting the ant. and what optimal range of SWR is. Once you are set you only need to check it maybe two or three times a year but usually they don't go out of phase, You can leave the meter inline and it will be fine as well as being able to keep your eye on your broadcast ability.
The units I buy generally cost in the range of $20 or so, not fancy but they work just fine...kind of a K.I.S.S. methodology IMO.
Old Dec 26, 2009 | 04:33 PM
DarkStarr's Avatar
DarkStarr
Shake n Bake!
cool, glad to see i dont need to spend much. thanks
Old Dec 26, 2009 | 08:02 PM
dubcac's Avatar
dubcac
I
Quit callin me radio, 91.
Quit callin me 91, radio!
Old Dec 27, 2009 | 05:48 AM
spanky's Avatar
spanky
I go duffy on dem bitches
Unit 91.
