Help Janna :o
(07:56:32 PM) Janna: and you, because you're moving.. keep going forward and the object is hurtled backward at a higher rate because of that
Are you sure that happens?
So youre saying if you are going east 50mph, and a pebble gets thrown at your windshield going west at 20mph from a car kicking it up...the pebble will bounce off your windshield and head east at a rate more than 50 mph or 20 mph?
if pebble is at 20 and cars goisng at 50 then peebebl hits the windshidl
It sounds like an example of an elastic collision:
In the example above, the target (i.e. your car) is not in motion whereas in your case it would be but I think the concept would still apply since the car's velocity should be unchanged by the collision...maybe.
Elastic Collision, Massive Target
In a head-on elastic collision between a small projectile and a much more massive target, the projectile will bounce back with essentially the same speed and the massive target will be given a very small velocity. One example is a ball bouncing back from the Earth when we throw it down.
In the case of a non-headon elastic collision, the angle of the projectiles path after the collision will be more than 90 degrees away from the targets motion.
Its called Relative velocity/Relative acceleration, if im understanding you correctly.
