LCD TV wall mounts v. help
http://www.ergotron.com/Products/tabid/65/Default.aspx
These guys make good ones.
Expensive, but nice.
Then go look at what Doug Mockett has to offer for flat panels.
Given the space you're working with, a pair of FSA1 single arm pedestal mounts are going to look and perform much better IMO than a generic wall mount.
The cables will be hidden and if you need to remove either arm, all you need to do is install a grommet that's the same diameter as the base of the pedestal.
Install one at the back corner of the desk and the other at the centerline of monitor where it currently sits at your workstation.
