AEM fuel rail
Old May 18, 2006 | 04:54 AM
JLO's Avatar
JLO
7M-GTE!!!! "U-BLOC BITCH"
Default AEM fuel rail
is there any point getting a fuel rail if i dont have turbo....ie what are the advantages of purchasing one of thease?
Old May 18, 2006 | 05:14 AM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
Most engines could REAALLY benefit from the added style in the engine bay. :goodjob:
Old May 18, 2006 | 05:45 AM
ISP James's Avatar
ISP James
DAMIMRED
with stock injectors, i do believe that your advantage is zero. and with a stock or mostly stock engine, there is no need for extra fuel so really, upgrading your injectors isnt worth the money. in the end for most people, its just a cosmetic change.
Old May 18, 2006 | 05:54 AM
LT's Avatar
LT
The deer had to die!
The factory fuel log will be good up until you need lots of fuel (re: lots of horsepower). For a basic, low-boost turbo setup upgrading the injectors would be more efficient.
Old May 18, 2006 | 07:07 AM
AP2's Avatar
AP2
Moderator Alumni
95% of the time, this mod will be worthless to you.
Old May 18, 2006 | 07:14 AM
JLO's Avatar
JLO
so essentially there is no point to add this mod unless i have turbo.....will it put a decrease in my gas mileage?
Old May 18, 2006 | 07:20 AM
ISP James's Avatar
ISP James
DAMIMRED
it will do nothing but look pretty. wont help wont hurt. its a waste of money, if you want pretty, i have a stock rail ill sell you for like 5 bucks and have it powdercoated.
Old May 18, 2006 | 07:33 AM
AP2's Avatar
AP2
Moderator Alumni
I've seen motor setups in the 400hp range running on the stock fuel rail. Most of the time people buy fuel rails to bore out the fuel injector ports to accomodate bigger injectors. As for a decrease in gas mileage, having a slightly bigger channel for a few inches isn't going to hamper the consumption of fuel.
Old May 18, 2006 | 07:58 AM
skabone69's Avatar
skabone69
I agree, there is not point to them on honda engines except to look nice under the hood. my buddies boosted 6th gen accord is running over 300whp, fully upgraded internals, bigger injectors, and stock fuel rail. he says the stock fuel rail can handle his fuel needs no problem.
