Need help diagnosing a car problem.
Old Feb 27, 2006 | 03:12 PM
RB's Avatar
RB
snitches get stitches
Default Need help diagnosing a car problem.
Most of my driving is 35 mph or less in a small town with lots of 4-way stops. Well, lately when I come to a stop at a 4 way stop with my clutch in, my car will suddenly just die. All the electrical stuff stays on, and when I crank it, it starts right back up and I'm off on my merry way, but I can't figure out why its happening. Also, when I'm cruising at a constant speed and let up on the gas then reapply gas, it sometimes gets really jerky for about a second. Neither of these instances (car dying at a stop sign or the car jerking) happen all the time, but it's happened probably 4-5 times in the last week and I'm beginning to wonder what is going on.
It's got new plugs and wires, new dist. cap/rotor, recently had the oil changed.
Any ideas?
Old Feb 27, 2006 | 03:32 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
check fuel filter?... had a similar issue... and turns out my fuel filter was siezing up... and how do ur plugs look?
edit: ur old plugs
Old Feb 27, 2006 | 03:41 PM
AcuraFanatic's Avatar
AcuraFanatic
edit: ur old plugs
I'm going to agree with you there. His old plugs looked like hell as well.
Old Feb 27, 2006 | 03:42 PM
reech-around's Avatar
reech-around
RIP Woong.
bad ignition coil? :dunno:
Old Feb 27, 2006 | 03:43 PM
RB's Avatar
RB
old plugs h:
RB's Avatar
RB
That was replaced less than a year ago
Old Feb 27, 2006 | 03:46 PM
swaggs21's Avatar
swaggs21
you might also want to clean out your IACV valve, that should help also.
Old Feb 27, 2006 | 03:47 PM
dubcac's Avatar
dubcac
I
Try new plugs. If it still does it, try fuel filter.
