Code 41: Primary Oxygen Sensor Heater (what do I do?)
Old Jan 31, 2006 | 11:25 AM
Pete's Avatar
Pete
Civilian
Default Code 41: Primary Oxygen Sensor Heater (what do I do?)
Can anyone help me out here? I am throwing this code and I have no clue what to look for or where this is even located. Thanks.
(attn mods: Posted here and in CRX forum for wider dissemination if that's okay.)
Old Jan 31, 2006 | 03:22 PM
dubcac's Avatar
dubcac
I
The O2 sensor is in your header. Replace it.
Old Jan 31, 2006 | 05:17 PM
AcuraFanatic's Avatar
AcuraFanatic
:werd:
And go Bosch. Save youself $180 over OEM. h: Bosch O2 sensors run about $80.
Old Jan 31, 2006 | 08:01 PM
kill_kill_kill's Avatar
kill_kill_kill
it's sarcastic dude
you'll need a special socket with a cut out section for the wiring to remove and replce the o2 sensor.
if you know how to solder you may be better of buying a "univesal" replacement sensor, apparently the plastic clip that the four wires go into is worth like a hundred dollars in price increase. I had this same thing happen to me so if you want any more info feel free to PM.
Old Feb 1, 2006 | 02:31 AM
Brad's Avatar
Brad
wooo nascar!
or you can just use a regular old wrench, or some channel locks.
Old Feb 1, 2006 | 03:47 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
Thats a good tip. I didn't know they made universal ones.
Also, I use an open ended wrench myself as stated.
