excel help
Old Jun 28, 2005 | 05:27 PM
Bl@ck's Avatar
Bl@ck
Sinner
Default excel help
ok.. basically i have this spreadsheet for calculating outage statistics for different areas of trouble call escalation.
what i want this particular cell to do is lookup the total outage time per issue per escalation level and come up with an average outage time per escalation level.
any ideas?
Old Jun 28, 2005 | 05:30 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
what kind of stats do you have in there? how's it set up?
Old Jun 28, 2005 | 05:34 PM
Bl@ck's Avatar
Bl@ck
Sinner
pretty much it's just trouble ticket open, resolution and total down time with a pulldown for each section in the escalation chain.
rows
Old Jun 28, 2005 | 05:53 PM
flipped cracka
i can do it with 3 cells for each level. i'm sure there's a better way to do it though.
i used sumif and countif. use sumif to add up the total time depending on the level, and then countif to figure out how many of each level there is. then divide the sumif cell by the countif cell to get the average.
Old Jun 28, 2005 | 05:55 PM
flipped cracka
ok, did it all in one cell. this is basically the formula:
=(SUMIF(A2:A9,1,B2:B9))/(COUNTIF(A2:A9,1))
=(SUMIF(range_to_test, what_to_look_for, cell_to_look_in, range_to_add))/(COUNTIF(range_to_count, what_to_look_for))
the ones are levels (i had different numbers for the different levels, you put what you need). let me know if you need more info than that.
*edit to explain it a little*
Old Jun 28, 2005 | 05:57 PM
Bl@ck's Avatar
Bl@ck
Sinner
that'll do donkey.. that'll do
thanks meng
Old Jun 28, 2005 | 06:23 PM
Bl@ck's Avatar
Bl@ck
Sinner
got it in one cell.....
=SUMIF($D$4:$D$84,"value",$K$4:$K$84)/COUNTIF($D$4:$D$84,"value")
again thanks
Old Jun 28, 2005 | 07:10 PM
flipped cracka
that's what i said.
you're welcome.
