does component video makes a big difference?
Old Jan 8, 2005 | 09:46 PM
kento's Avatar
kento
Default does component video makes a big difference?
i have a sony wega tv with component video in, and my dvd player has the component video out... is the picture that much different than regular RCA video in?
Old Jan 8, 2005 | 09:47 PM
randomtask77's Avatar
randomtask77
Wanderer
I'd like to know this as well. h:
Old Jan 8, 2005 | 09:49 PM
AP2's Avatar
AP2
Moderator Alumni
Ooooooh yeah, I use it whenever I can. PS2 looks much cleaner with it.
Old Jan 8, 2005 | 09:56 PM
dubcac's Avatar
dubcac
I
Yes. I heart component video on my parents' Grand Wega.
Old Jan 8, 2005 | 09:59 PM
Brad's Avatar
Brad
wooo nascar!
i think if you have a high quality tv (at least a flat tube) it would make a noticeable difference. but on an older standard tube tv probably not so much.
Old Jan 8, 2005 | 10:22 PM
Misa's Avatar
Misa
Pic Whore
it makes a difference with my 61" Projection
Old Jan 8, 2005 | 11:35 PM
umop-apisdn's Avatar
umop-apisdn
Allergic to vitamin D
Since you are going from RCA to component, then yes, there will be a big difference. Going from s-video to component is not as big of a jump.
Old Jan 9, 2005 | 12:21 AM
Anthony's Avatar
Anthony
ZOMG Pew Pew Laserbeams
which one exactly is component if someone will show me/explain to me
Old Jan 9, 2005 | 12:36 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
On regular TV's, the luminance channel (brightness basically... if you were to plug just a certain one of the component inputs in, you would get just a B&W picture) is sent separately from two different color difference channels. Thus, compared to a normal composite (where all 3 channels are mixed and compressed, leaving the TV to decode this) and S-video (where just the luminance is separate from one mixed color channel, basically better than composite), the composite allows for higher picture fidelity because it can offer 3 times the bandwith of composite, and without channel cross-interference... thus, superior picture.
You can get even higher picture quality (in terms of picture resolution) over component if your display systems support it. For example, the only way to display EDTV (480p) and HDTV (720p and 1080i) is over these cables. But that's another discussion altogether
Old Jan 9, 2005 | 09:23 AM
sids1045's Avatar
sids1045
dumber than a box of hair
I've tried it both ways. Component video (three video paths) definitely looks better than composite (one video path).
