03 Accord - How can I remove trim panels to route power wire for amp?
I just got a 03 Accord Coupe and I'm trying to run a power wire to the trunk for my amp. I'm sure plenty of people have done this, but how can I lift all the trim pieces so I can neatly hide the power wire?
I brought the wire in through a rubber grommet that holds a large group of wires. Hope there's not too much EMF interference this way.
I'd also like to know where I can connect my remote turn on lead. Anyone know which wire I can use that comes on with ignition?
Thanks
Thanks
Re: 03 Accord - How can I remove trim panels to route power wire for amp?
HAN's resident 5-0
the door sills just pop off, then from there you can just push it under the other panels, and feed it under the seat into the trunk, under the trunk panel.
Now if I could only figure out which wire to use as the turn-on lead for my amp.
