How much are NSX Rims?
Old 07-04-2002, 05:22 PM
TypeR240
TypeR240's Avatar
Default How much are NSX Rims?
I have an Integra Type R, and I badly need bigger wheels. These 15's it came w/ cant seem to handle any engine upgrades. So my question is how much are NSX Rims and what size are they? I figured it would look nice to keep the Acura brand on the wheels instead of some other aftermarket name.
Old 07-18-2002, 02:29 PM
AcuraFanatic
AcuraFanatic's Avatar
Very expensive...$1200 for four wheels without tires.
Old 07-19-2002, 07:40 AM
EliteAccord
Banned
EliteAccord's Avatar
That ain't that bad.:thumbup:
Old 07-19-2002, 09:24 AM
nsxtasy
nsxtasy's Avatar
Default Re: How much are NSX Rims?
You can read about the size of NSX rims in the "Wheel Tech" section of the NSX FAQ (answers to Frequently Asked Questions), which is located here.
There are serious problems in using them on an ITR.
The NSX front wheels have a larger bore hole than the ITR wheels, so at a minimum you would need hubcentric rings (which, although better than NOT using rings, is not as good as matching the bore hole); furthermore, the wheels are wider than the ITR wheels, and they will rub on the suspension unless you use spacers.
The rear wheels have the same bore hole as the ITR, but the offset is much further off and they're a lot wider, so they are even more of a problem than the front wheels.
All in all, you would have to be making some serious modifications to get them to work. Not recommended.
And the price quoted above is way off. A used set of '91-93 NSX wheels (15" front, 16" rear) typically changes hands for $100-200, maybe a little more if they have decent tires on them or if they're in perfect condition (which few are). Nobody buys them new, but if you did, you'd probably be looking at $2000 or more. A used set of '94-01 NSX wheels (16" front, 17" rear) in very good condition typically changes hands for $1500-2000, more if they have decent tires on them. You can get a new set for around $2800.
Old 02-24-2006, 11:47 AM
turbovtec935
turbovtec935's Avatar
Default I have a set of nsx rims
I have a set of nsx rims for 400 with tires i only have two tires on the fronts which are 15s and the backs are 16s with no tires if you are interested please email me back tghanks
Old 05-17-2006, 05:54 PM
SirHybrid
SirHybrid's Avatar
isn't the offset way different since the nsx is rwd?
Old 05-20-2006, 05:08 AM
Chris_s2k
Chris_s2k's Avatar
I can get some brand new OEM 05 nsx wheels for around $1200 a piece
Old 06-21-2006, 11:04 AM
TSM
TSM's Avatar
Those rims aren't fitting on an itegra maybe if you get the ft's of a early model but they are ugly the new ones 00-up are like 1200 each from the dealer
Old 06-22-2006, 02:16 AM
evolution
早晨好, 先生們!™ 粉腸+ 春袋
evolution's Avatar
This was a four year old thread.
Old 12-31-2007, 05:12 AM
nicholas_nsx
Banned
nicholas_nsx's Avatar
I have an 03 NSX and if your still interested in stock wheels, send me a private msg. Looking to sell.
Quick Reply: How much are NSX Rims?
