Foggy Headlight Housing!!
You are teh suxorz
i noticed tonight that my passenger side headlight housing is very foggy compared to the right side.
i have tried opening up the headlight but thye blue (aftermarket black housings) is far to caked on to wanan come apart.
is there any way to get rid of this fog w/o opening the headlight?
thanks.
thanks.
rebmeM roineS
add more silcone all around the edges, coat that shit on there thick as hell on every seam you can see. also make sure theres a good seal where the bulbs go into the headlights.
You could use a heat gun and melt the glue and push it together firmly again....to get rid of the condensation inside just take a bulb out and use a heat gun/hair dryer to dry the inside out through the hole.
cx power!
Location: berkeley, ca --> la, ca representin' tha 510&626
Originally posted by RaceACCORDingly
but would that de-fog whats there? if i use a hair dryer?
You are teh suxorz
ok the mess of stuff is on the inside of the lens, it looks like someone put fingerprints all over it, what if i took a cloth and a wire and tried to kinda whipe it off
