Gs/ls/gs-r?
Old 03-24-2003, 05:14 AM
NVS
That's Mr.NVS to you!
NVS's Avatar
Default Gs/ls/gs-r?
My '92 Integra didn't come with a owner's manual, and I don't know what model it is. How can I find out? Does it really matter(in terms of adding mods)?
Old 03-24-2003, 05:19 AM
Deludedteg
Deludedteg's Avatar
If it has VTEC it is a GSR(I think they had VTEC for this year although I am unsure. Someone correct me if I am wrong). If not then it is an LS/GS/RS/SE The only difference in the latter is the trim level. The RS doesn't have a sunroof.
Old 03-24-2003, 06:07 AM
Singhg83
BALLIN'
Singhg83's Avatar
when you open your hood, look at the motor, if it has the VTEC name on the motor, you hava gs-r.
Gs is just basically having every option (suspension, rims etc . ) being the same as the GS-R but not having the GS_R motor.
LS is has a few options less than the Gs. It soes not have the stock rims, suspension is the same as the RS, stupid crap like that.
Rs is just the base model integra, no sun roof etc . ..
hope this helps
Old 03-24-2003, 06:17 AM
NVS
NVS's Avatar
Which has the better engine/motor?
Old 03-24-2003, 06:19 AM
ur31337
Colby
ur31337's Avatar
GS-R. You would know if you had a GSR, the gearing would be real short, your redline would be higher. You would have alloy wheels, a GSR badge & some other junk.
There were a very limited amount of 92-93 GSRs.
Old 03-24-2003, 08:03 AM
eclipse spanker
eclipse spanker's Avatar
The gs-r motor is better, it has more power. but as far as mods are concerned, all nonvtec models (ls,rs,gs), use the same engine (b18a), and the gs-r is the only one that uses a different engine
Old 03-24-2003, 11:55 AM
Singhg83
BALLIN'
Singhg83's Avatar
boosting, however, is a different story. It would be better if you had an rs/ls/gs because vtec and boosting dont mix that well.
Old 03-24-2003, 12:32 PM
DB7 2.0
Banned
DB7 2.0's Avatar
your 92 Integra is not a GSR most likely. if you had one, i highly doubt you would ask if its a GSR. and assuming its not a GSR, the engine you have is a B18B nonvtec.
as for the which trim...depends on minor things here and there. first off, what wheels do you have? hubcaps? 14" 6 spoke alloys? if theyre aftermarket wheels, then forget that question.
do you have leather? if yes, then you have a GS.
is it auto? if yes, then 100% you dont have a GSR.
what color is the car? if its not white/red/teal, again 100% you dont have a GSR.
do you have a sunroof? if not, its an RS.
are your side moldings and bumper moldings body color? if not, then you dont have a GS for sure.
do you have air conditioning? if so, you dont have an RS for sure.
and so on and so on.
we cant tell you what model you have without any specs/options listed.
Old 03-24-2003, 12:54 PM
NVS
NVS's Avatar
Do they all have back seats? Mine is a blue two-seater. Kinda like a del-sol. The hatchback is right against the front two seats.
Old 03-24-2003, 01:08 PM
stevieteg
stevieteg's Avatar
yes all integras have back seats. You might want to check more into that situation. If there are no back seats in your car it has probably been raced or stolen or some thing of that nature.
