97 2.2 CL Brake Bleeding
Old 10-11-2009, 04:19 PM
bob3700
bob3700's Avatar
Default 97 2.2 CL Brake Bleeding
I replaced the front brake pads on my 97 2.2 cl. Have done this job a couple of times and never had any issues.
This time, the brake pedal is very long. Goes about 3/4 of the way down before the car begins to stop. If you pump the pedal, it comes up. That would tell me I have air in the system.
I used the pressure bleeder and ran a good pint of fluid thru each front caliper. No air bubbles came out. Pedal is still long.
The car has ABS, does this require any special procedure for bleeding the front calipers?
Help!!!!!!
Bob
Old 11-06-2009, 06:10 PM
caramilk1212
Banned
caramilk1212's Avatar
A1 CARDONE FRICTION CHOICE BRAKE CALIPER, SOLD INDIVIDUALLY -- Remanufactured; Includes all necessary hardware for quick and easy installation; Features OE quality seals, boots, and bleeder screws; Phosphate-coated to prevent rust and extend life; A high quality, direct fit OE replacement brake caliper; With A1 Cardone's limited lifetime warranty.
Nashville TN Luxury Homes Utah Pergolas
