Reseting ECU
Old 11-20-2002, 07:53 PM
VtecRacer
VtecRacer's Avatar
Default Reseting ECU
How do I reset my ecu? it's a '98 Civic Sedan
Thanks
Old 11-20-2002, 08:13 PM
inspyral
のんびり~(´ε`)
inspyral's Avatar
You can either 1)pull the negative battery lead 2)pull the backup fuse in the underhood fusebox 3) disconnect the ECM at the plugs.
Old 11-20-2002, 08:27 PM
VtecRacer
VtecRacer's Avatar
so just pull the negative batt. out?
how long do I leave it out for... any specific time interval before plugging it back?
Old 11-20-2002, 08:29 PM
EKHatchRacer
EKHatchRacer's Avatar
does it really help to reset the ECU?
Old 11-20-2002, 08:32 PM
VtecRacer
VtecRacer's Avatar
Well whenever you do changes such as intake/exhaust, you should reset your ecu so it can adapt to it.
my mileage is horrible, probably around 350km's per tank
should be 4-500km's
Old 11-20-2002, 08:43 PM
whiteEJ8
whiteEJ8's Avatar
I usually leave it disconnected for about 10 minutes. I don't know if it's necessary to leave it unplugged for a certain amount of time but I just do it to be safe.
Old 11-20-2002, 09:10 PM
inspyral
のんびり~(´ε`)
inspyral's Avatar
Just disconnect the ECM plugs for 10 seconds. I usually do that, so it doesn't mess up my clock and stuff.
Old 11-21-2002, 03:10 AM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
http://www.jdmfan.com/technical/other/troubleshoot_dtc/
2nd table on the page.
Old 11-21-2002, 06:57 AM
HatchVX
Driving a Turbo 2L Terror
HatchVX's Avatar
When you reset ur ecu once u plug it back up, start it up but DONT NOT TOUCH THE GAS, wait until the cooling fan comes one once then u can touch the gas. That period of time lets the ECU Adapt to the new edition u put on.
Old 11-21-2002, 12:40 PM
SpeedRacerEX-R
SpeedRacerEX-R's Avatar
I must've messed up a lot of cars fuel maps. I let it idle for about 10 seconds and I'm off.
