Difference between SOHC VTEC & DOHC VTEC ???
Old 11-16-2002, 08:57 AM
Myztikal
2000 Prelude Type SH
Myztikal's Avatar
Default Difference between SOHC VTEC & DOHC VTEC ???
i heard from my friend that Duel Over Head Cam is nuttin without VTEC but what about having Single Over Head Cam with VTEC ???
whats teh performance difference betweeen SOHC VTEC AND DOHC VTEC???
Old 11-16-2002, 09:04 AM
HappySnatch
OG
HappySnatch's Avatar
Default Re: Difference between SOHC VTEC & DOHC VTEC ???
your friend is a dumbass. anyway the dohc vtec engine uses two cams, one for the intake and on for the exhaust (they are independent). the sohc vtec uses one cam for both the intake and exhaust side
the dohc vtec engine has more potential
Old 11-16-2002, 09:29 AM
inspyral
のんびり~(´ε`)
inspyral's Avatar
Even if a SOHC and DOHC are making similar power, the DOHC will have more torque, and the independent intake and exhaust cams will allow for more tuning options.
Old 11-16-2002, 09:33 AM
crucial Si
Banned
crucial Si's Avatar
not really..comparing the d16 to b16...they rate the single cam only having 107 lb/tq and the dualcam at 111 lb/tq...which ive read that to the ground the single cam puts out the same or more to the ground.
Old 11-16-2002, 11:00 AM
Jkan2001
S2000 Pilot
Jkan2001's Avatar
and even if the sohc doesn't put more down....a turbo can fix anything
Old 11-16-2002, 12:19 PM
crucial Si
Banned
crucial Si's Avatar
there was a 6th gen si w/ a bodykit and 17 axxis seven rims at the track last night on a greddy turbo kit w/ fmic...he ran 15.4 constaint times....fawking pathetic.
Old 11-16-2002, 02:17 PM
Tirod
Tirod's Avatar
another camshaft
Old 11-16-2002, 05:17 PM
90TGP
90TGP's Avatar
Tell your friend to line up next to a Corvette ZR1 with the LT5 DOHC V8 with no variable valve timing, then let's see what he says about DOHC being worthless without VTEC.
Old 11-16-2002, 05:49 PM
elballoonrat
elballoonrat's Avatar
supposedly someone in japan is making a aftermarket bolt on kit for nissan sr20 engines, i know this can be adapted to 3sgte's and 4age's, it would be interesting to mount up the small port 4age's head to a b-16 block and see what happens, although the motor do turn in different directions, im not sure how this would affect it( plus the fact the plumbing would be all wrong...but still...in theory...a toyota atlantic head on a 12:?:1 compression motor would be crazy rev happy)
Old 11-16-2002, 08:05 PM
crucial Si
Banned
crucial Si's Avatar
:wtf: very useless info....
