2003 Accord EXL (Dual Climate Controls) Amp & Speaker Install
So I did a little searching, and I couldn't find anything that was a good explanation.
What's the easiest method to add an amp & aftermarket speakers? I wanna keep the factory deck. I want the amp and such in the trunk, so do I need to tap into the wires behind the deck? If so, I'd like to make this system removable. So could I tap in some kind of leads like those thingamajigs that slide together? Would I even need to cut the wires in the first place, or is there some kind of adaptor I could buy?
Also, what size speakers do I have? It looks like 5 1/4 in the fronts and I've been reading 6x9s in the rear, is that right?
P.S. Last visited on 12-5-05!!! Yea for being active!!
first, yes you can get a unit to splice into the speaker wires and use your original HU and install aftermarket speakers and amp/sub
if i find the diy on it I will post it, I just need to find it
my 98 honda accord lx has 6.5" in front and 6x9 in rear
MalleusMaleficarum
They are 5.25 in the front doors. Our 6th gens had 6.5's, I wonder why Honda switched?? Be careful when removing that radio, the pocket below the radio is easily broken.
