1993 Accord brake rotor replace tips.
Old 01-05-2006, 01:09 PM
firefox
firefox's Avatar
Default 1993 Accord brake rotor replace tips.
Hi guys.
I've done disc brakes in the past with many cars, but this is the first time I've had to remove the axle bolt to remove the rotor. Is this true of was I inhaling too much asbestos when I was looking at it?
And if this is the case, do you guys have any tips? From what I read, I have to chisel the metal that's folded in, remove the axle bolt, use pry bar to keep the rotor/hub from moving, then slide it out after I remove the cv.
Thanks!
Fox
Old 01-05-2006, 02:24 PM
firefox
firefox's Avatar
Default Dope! Found the PDF
I found the pdf and I've gone through this. Very similar to what the Hayes manual says.
So after the caliper is out (<10 mins for me) I need to...:
1. Remove the spindle nut
2. Remove 4 bolts from the back holding the rotor
3. Push the axle in, and the axle should pop out of the hub?
4. Mallet/hammer the rotor out.
5. Remove the hub assembly.
Does this sound right to you guys?
Man, why did Honda do this? This is the most painful rotor replacement I've done in my life. I've replaced rotors on Audi's, Toyota's, and Nissans and they were 1/2 as bad as this one.
Thanks!
Fox
Old 01-05-2006, 02:30 PM
waaBAAH
waaBAAH's Avatar
gotta love the accords.....yeah the front rotors are on the hub itself. your right. i cant recall but i think there are two bolt holes on the hat of the rotor facing outward. if the rotors are stuck you could use a bolt and thread it through the bolt holes on the face of that hat. but yes you do need to take off a lot of stuff on 90-97 accords. another tip is to really take the car to a shop if all you need is resurfacing. the will put the vehicle on the "on-the-car-brake-lathe" to resurface them.
Old 01-05-2006, 02:31 PM
preludeH22a
i'm pretty much awesome
preludeH22a's Avatar
i think on those accords, you have to take off the steering knuckle and remove the 4 bolts that hold the hub unit on there. and then there are 4 more bolts that hold the rotor on the hub. and the axle nut is easiest to take off by taking your wheel off and taking the center cap off, putting the wheel back on, lowering the car back down and putting the socket through the center hole. if your wheels dont have a big enough hole, the spare wheel should. dont worry about the metal thats folded in on the nut. it shouldnt stop you from getting it off.
hope this made sense.
Old 01-05-2006, 02:56 PM
firefox
firefox's Avatar
Man's got to know his limits. I'm going to ask around and see if I can find a shop that will do the "on-the-car-brake-lathe" and see if my rotors can be turned. That should take care of it for a while.
The idea of turning the axle with the wheel down is a nice idea though. I'll give the lathe a shot, and if that fails, I'll start braking this thing down.
Fox
Old 01-05-2006, 10:47 PM
wedley2
bboy Wesley West
wedley2's Avatar
i have a DIY on this specific model and yea...it took me 8 hours for both sides.
Old 03-18-2006, 10:57 AM
Ahhcord EX96
Ahhcord EX96's Avatar
is it really hard to get the rotors off fromthe sterring knuckle arm? cuzI tried and sheesh! damn rotors wont come off. waht do I do to get it off? good car bad way of designing the rotors. So im all over trying to find answer to this and how to take it off. Please let me know. If theres a tool that is used to get the hub off and apart fromthe steering knuckle let me know.
Old 03-18-2006, 04:55 PM
wedley2
bboy Wesley West
wedley2's Avatar
you have to pound them out with longer bolts of the same thread.
Old 03-18-2006, 07:57 PM
Ahhcord EX96
you know man your so helpful! jsut today a friend of mine toldme the same thing I tried no to ask him cuz dont wanna boost his ego (laughs) but i came home and to check my email with a reply i had gotten from you in HondaAcura site man you said to do the same thing he did which is totally awsome!
So I'll go and try that out when I go to school only I'll thank you for it mostly and tell my instructer that I had done a research onhow to do it and some cool guy had helped me out. This way shows I worked on researching whichis a good thing. So thanks for the tips yo and Ill get back at cha when I get it the damn thing out!
PS you got an Accord what year? ya got pix? could you send tome on my email ? if you can. you can check my Accord out in this site Honda Show Off only mines a bit scarry lookin LOL Im not done with it.
http://hondashowoff.com/profile.php?id=4823
Old 03-18-2006, 08:38 PM
Autumn Drive
V8 powered
Autumn Drive's Avatar
it took me all day to remove mines.
