changing exhaust
01ACCORDEX
changing exhaust
I SEE A LOT OF FOLKS PUTTING TL EXHAUST ON 6th GEN ACCORDS, BUT IS IT POSSIBLE TO ADD V6 EXHAUST FROM ACCORD TO 4CYC ACCORD? IF SO, IS ANYTHING ELSE NEEDED BESIDES EXHAUST PIPES AND TIPS?
Do you mean just add a second muffler or swap your system for the complete V6 system?
I have TL-S mufflers on my car, but with custom piping to get them to work. Not a performance mod, but much better than the limp penis stock I4 bent down exhaust tip. Sounds better than stock, but not loud and obnoxious.
01ACCORDEX
i just want the "look" of an v6 on my I-4. so, i can just buy the 2 mufflers and have some custom pipe work done to make it work? ur TL pipes look good. did u get them from a junkyard or what? and where can i find clear headlights?
01ACCORDEX
anyone know where i can purchase oem v6 mufflers for 01 accord or TL mufflers? i want to put either on my I4. i found a place to do the work for me, im just having trouble finding the mufflers.
I got mine off a TL board. Headlights...you can DIY...basically warm up the headight assembly enough that you can pull the front and back apart, remove the amber, paint certain parts black if you desire, and reassemble. There are a lot of detailed DIY writeup's out there if you search. You can buy them clear, but the aftermarket lense isn't quite as bright. Mine are a DIY.
Originally Posted by BROMOZEE
heat up the headlight assembly?! i dont put it in boiling water do it? the microwave?
