Clutch Problems
Clutch Problems
Im having a problem with the clutch of my 98 Civic HX. The pedal goes to the floor, but does not spring back. A friend of mine suggested that either the master or slave cylinders have gone bad. I have identified a leak of clutch fluid at the front of what i think is the slave cylinder, where the metal and "slinky rubber boot" join. Could this be the cause of the problem, what parts should I buy, and how easy is the fix? I really know very little about repairs, and have never changed a master or slave cylinder. Any help/advice/suggestions would really be appreciated.
Sound like the slave cylinder, which only runs you about $12.00 dollars at Oreily's auto parts, or any parts store for that matter.
I had the same problem and thought it was the master clutch cylinder and bought one for $70.00, but figured out it was not the problem but rather the salve cylinder, which I just now bought during lunch.
I have a leak at the slave cylinder, and it does not look that hard to replace either. Here is a link to the break down of the system.
http://www.hondaautomotiveparts.com/...ASTER+CYLINDER
