'05 dyno plot from 5/14/05
Old 05-15-2005, 08:45 AM
shivers
Moderator Alumni
shivers's Avatar
Default '05 dyno plot from 5/14/05
Some friends set up a dyno day over the weekend. I decided to jump on the rollers to get a baseline. 1450 miles on the clock, so it should continue to pick up a bit as things loosen up over time. Three runs were done back to back with coolant and air temps stablized. The dyno used is a Dynodynamics (load bearing), so the numbers will probably look different to you if you're not familiar with this type of dyno. In Dynojet numbers, the car puts down about 215-218 at the wheels. Enjoy.
2005 s2000
Old 05-15-2005, 01:13 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
Looking good. You going to do anything to it? :goodjob:
Old 05-15-2005, 04:44 PM
Snoopy
been there done that
Snoopy's Avatar
i wonder where vtec kicks in? :chuckles:
Old 05-15-2005, 06:52 PM
shivers
Moderator Alumni
shivers's Avatar
I'll put on an intake and some mild fuel mgmt (VAFC2/eManage) on the car at some point ... nothing major. There's more power to be had even in the stock configuration since the a/f ratio was in the low 11s most of the time only leaned out to a low 12 at the crossover.
2005 s2000
