run switch to start car so cannot be stolen
well i want to put a toggle switch to the ignition so you cant start it unless the switch is turned on. so it cant be stolen. actually what i want to use for the switch is the cig. lighter push it in then turn the key to start. any one know how to do this?
On permanent hiatus
That would be too obvious. This would be much more effective: http://www.teamdelsolwa.com/howto/fuelcutoff.htm
I have a friend who wired his kill switch to his horn. he has a switch that switches his horn to his kill button. So in other words, he flips a switch and pressing the horn button will make the horn noise, when it's switched the other way, you have to hold down the horn in order to start the car. What's the last thing a thief is going to press in your car to avoid bringing attention to themselves?
there are 2 wires on the the back of the cig lighter cut em off, cut ur starter wire hook one end up to one wire and the other to the other wire.. and ur good to go, push the lighter in and start it up and ur good to go oh and the wire is a black/white 10gauge wire, around that size anyway, should be in the same harness as a yellow a white and a black/yellow wire.
